RE: 8s Charge Setup
The balance plug from one pack would be plugged into the balance port on the charger, the other packs balance plug would be plugged into the blinky, while charging both connected in series. Each pack would be balanced while charging. If you don't have multiple chargers, this is the most straightforward way I know of to do it, if you want to balance while charging.
