I believe what's most important is the distance between the two wires being the same at the servo end and surface end so that they are parallel. Having the servo arm, wheel, etc.. in alignment with the horns is also good practice. The farther you get from opitmal alignment, etc the less mechanical advantage and more difficult to tune it will be. This is just my understanding. I have set up pull pull on rudder before but that's it.
There is much info here:
http://www.mindspring.com/~rellis2/rcpattrn/ppull.htm
