RCU Forums - View Single Post - Pull Pull servo placement
Old 11-03-2009 | 05:52 PM
Mode One
Default RE: Pull Pull servo placement
I disagree with kit builder. If the servo arm is smaller, you simply wont get as much throw as you would if the arm was the same or bigger. There is mechanical advantage (more leverage) to a smaller servo arm, which is a good thing, if you end up with the amount of throw you need. Having the elevator servo upright is o.k.
