RCU Forums - View Single Post - Tight joints?
Thread: Tight joints?
Old 07-03-2003 | 06:05 PM
GeraldO
Default Tight joints?
I usually cut balsa with a new sharp single edge razor blade. Most of the time I can get the sticks very close to the desired length and cut angle. But I usually cut just slightly longer than necessary and finish it with a swipe or two of a sanding block, trial fitting till it fits perfectly.
It's time consuming but that's just the way it is.
