ORIGINAL: Jacque
cloudancer, I have used Nelsons Paint alot. There is anouther way to paint your plane. I have used a black foam brush, and if you get it thinned right it looks as if it was sprayed. try it also on a box or a sheet of plastic. Just anouther way......
I bought a SATA Dekor 2000 fine finishing spray brush from EBay. It's so expensive, I don't want to use it in case it gets clogged!
