RE: Second Plane
I'm with DenverJayHawk-Big Stick 60 was my 2nd plane-very stable-you can load a big engine in it-it is as fast as your thumbs can move-set mine up with digital servos on 6 volt-I glassed the center of the wing only because I lost a trainer to wing failure on a factory joint right outside where I epoxied the wing together-it's a great plane-mine's actually down rightnow because of an engine failure and an unfortunate meeting with a steel pole-check out the crash and rebuild forum- the post is just after Prop Bitten I think it's on the 3rd page now it says Big Stick Down-Good Luck.
