RE: Graupner Inspiration build thread-Flown
Not with the inlet tracks supplied. I think the inlet size is OK, but the sleeves reduce for the turbine tank system, the tail outlet could be 100mm (4") so plenty of scope. It is light the wing from the box is 1227gram (about 43 oz)
If you could mould foam inlets then yes.
Dave
