ORIGINAL: CrateCruncher
A pilot of a very light (1/2 pound) electric plane is flying in calm conditions at 40 mph
ground speed. A front rolls in changing the conditions to a headwind of 20 mph and a 60 mph
airspeed required to maintain the same ground speed. (1) What is the effect on AOA due to change
in speed AND an added ballast of 3/4 pound? (2) How is control sensitivity effected by the
change in weight at the higher airspeed?
weight(mg)= 0.5 lbm (slugsft/s^2) weird units huh?
wing area= 1.29 ft^2
V1 = 40 mph(58.7 ft/s)
V2 = 60 mph(88.0 ft/s)
airfoil: naca 0006 (cl/AOA data from Abbott, pg.452)
air density (R) = .002378 slug/ft^3
1) Starting with the equilibrium between weight and lift we have:
weight = 0.5*(air density)*(velocity squared)*(wing area)*(lift coefficient)
mg = .5R(V^2)S(Cl)
Rearranging terms to get Cl:
Cl = (2mg)/[R(V^2)S]
Airspeed w/o ballast(.5) w/ballast(1.25)
Cl AOA(deg) Cl AOA(deg)
40mph 0.10 1.0 0.24 2.5
60mph 0.04 0.2 0.11 1.0
Notice the AOA of the plane without ballast is very close to zero at the higher airspeed while
the ballasted plane restores the AOA for level flight back to one degree.
2) Sensitivity of +/- 0.5 degree change in AOA at 60mph:
Weight AOA Cl Net Force(Fr) Fr/W*100(%)
0.5lbm +.7/-.3 +.1/-.05 +.7/-1.1 +140/-220
1.25lbm +1.5/+.05 +.2/+.05 +2.4/+.6 +92/-52
Pitching the plane half a degree has a dramatic effect on the plane without ballast. In the last
column the unbalanced reaction force is divided by the total weight of the plane. The
unballasted plane is virtually uncontrollable.
Gotta interject some reality into the "theory"
1. How many 8 ounce electrics (they ARE the fastest `1/2 lb models) can hit 40 mph?
2. pitch change of one (1) degree?
ouch!! I'll say 1/2 degree has adramatic effect!
That is a loop on most of that stuff
one degree is 1/4 " in one foot.
Our pattern planes typically never trimmed out with a pitch change of more than a tiny percentage of ONE degree.
anyway 8 ounces in 40 mph is unmaneuverable as is 40 POUNDS in 40 mph
contests are called at 20 mph
Slope gliders -an entirely different approch to flight -can tolerate speeds up to -likely 300 mph but there is no maneuvering done - Numberss are nice but why not use some realistic ones ??
