RE: Uneven braking
If it is of the type of brake that uses an expanding O'ring, then you can use an O'ring lubricant, B.V.M. can sell you one.
This usually improves things and and helps to prevent the wheels locking under braking.
Ensure the brake lines to both wheels are the same length
