RE: HINGES
I also use Robarts quite often. Only thing is, you need to have enough balsa that is thick enough so the hinge is not real close to the edges. I will say that I have never had a CA hinge break or pull out. I use them mostly up to 60 size. Robarts after that. I use the pacer hinge glue also.
