ORIGINAL: dave de
well guys, I got my elevator problem fixed with some great input. This is most likely a question for Tom. I have had zero problems with my engine (3mm-toc-53) However, I flew the plane the other day & it started great, the next day the engine started to flood very quickly & I couldnt get it to fire. With the regular starting procedure choke closed I would get a good it to start then quit, then open choke & start pretty quick. Now, with choke closed I get just a quick pop not really a start. I asked in the gas engines forum & someone said I might have a air leak in the crankcase,,,,,, any thoughts, Dave
First, I doubt it's a flooding problem. The way to check this is to pull the spark plug out when you get to the point where you think it's flooded. If the plug is filled with gas, you're right. If not then it's a different problem.
Do this test then report back, or just call me.
TF
