RE: Weird Engine Behavior
I agree with the air leak prognosis. Heat up the engine with a heat gun and plug the carb and exhaust with rubber corks. While blowing on the fuel line to the carb spray the engine with a soap/water solution. Any air leaks will show up as bubbles.
Good luck!
