RCU Forums - View Single Post - UAT QUESTION
Thread: UAT QUESTION
Old 11-06-2009 | 07:28 PM
FILE IFR 's Avatar
FILE IFR
Default RE: UAT QUESTION
ORIGINAL: BillJ
I assuming this tank should remain unchanged after a flight
Correct.
You MUST have an air leak at the UAT nipples to fuel/ fill lines. Using Tie-wraps to the nipples will not allow a perfect seal... use stainless steel tie-wire.
... Another overlooked problem for very few people is the use of a common screw to plug the fill line after filling... this will 'leak' as outside air will slowly follow the threads of the screw to the UAT tank.
