RE: Quick question.........IHOPE
If you believe the engine is not adjusted too lean, do Two other things, 1- add a shim under the head to reduce compression.. 2- use a colder plug. You may need to realize also that if the rear bearing is failing, metal particles from it may be getting into the combustion chamber and hitting the coil at supersonic speeds and damaging the platinum element.
