RCU Forums - View Single Post - Larger Revolver
Old 11-07-2009 | 05:47 PM
jet22b's Avatar
jet22b
Default RE: Larger Revolver
Here are my specs:
Weight 9 pounds
CG As Per The Manual
Engine OS 91 SPII ( 4 stroke )
Prop 14.6 Master Airscrew K Series
Onboard Glow System.
Now to get some good weather for her first flight. Over all, the build was good. I did the mod for the landing as was done on the little one. They put a floor in the canopy so the pilot can be glue to. The throttle servo now sit behind the fuel tank, but you can remove the tank without removing the throttle servo. As for the covering, I had one spot on the hatch that I had to smoothout, but, everything else was tight. As for the color they have on this revolver, I must say I like it. The blue come alive when the sun hit it, ie metallic type!! Like I said before, I can not wait to get some good weather for the test flights. Yes I will have the little one with me so I can take notes on both. Will post my finding on the test flight!!!
Have a great weekend everyone!!!
Sonny
