RCU Forums - View Single Post - KV-2 build
Thread: KV-2 build
Old 11-08-2009 | 08:01 PM
Flyn Chris's Avatar
Flyn Chris
Default RE: KV-2 build
On to the next page, the photos below shows the end of steps 5-8. Doing the torsion bars was bit futzy, I played around with the first one quite a bit till I figured out the proper technique of twisting the torsion bar with a needle nose pliers in one hand and the swing arm in the other. I did find it easier to remove the rear panel to do the last torsion bars on both sides. For wheel bearings and axles, the instructions show using the included grease, I used a ultra thin hobby oil instead, the wheels spin like they are on ball bearings now.
ID:	1310394   Click image for larger version
