Hostetler Pitts S1-11
Hey All,
Going to start building a 35% Pitts from hostetler plans, (purchased here on RCU) and I have a couple Questions.
First off, The plans state finished weight at 22-26 lbs. I am going to lighten it up a bit as all the wing ribs are shown solid and I am going to cut lightening holes in all but main ribs for mounting.
Also in some of the fuselage will be some lightening done. All up finished weight I am shooting for is around 18 lbs. or so.
What servos and engine size for this plane?
Would like to do a conversion engine as I am on a tight budget .
I appreciate any and all info given. Has anyone here built this plane, and if so, what motor and servos did you use? How did it fly?
Thanks in advance, David
RENORACER
PS: I am hand cutting, and selecting all the parts myself. only using landing gear ,cowl ,canopy and such from other sources.
