RE: Sig Smith Miniplane
The Saito 56 Golden Knight is exactly what I have been using. I believe it to be a great match, but I still fought the torque (I think it is also referred to as "P" factor).
I don't think you can prevent it from ground looping all the time if you fly off of grass. When I was flying off of a paved runway in Denver, I was eventually able to get her straight down the runway fairly consistantly. Throttle and rudder management was the key. Throttle into it slowly and use your rudder.
A Gyro would help this combo significantly, but personally, I like to figure it out without the extra aid.
It will not do 3D, but will fly very well with this combo. This is the combo I used for years and I know it to work very well. It is a good match with PLENTY of muscle.
Brian
