RE: CD ScaleDesigns Albatros CI build
Blind nuts, yes, that's the terms I forget over and over. So, after taping off the "gluing surfaces" I put on a couple rough coats of varnish. Now when I glue on the side panels I'll only have to worry about glue spotting on those side panels and not the formers. Well at least that's something. The second coat of varnish didn't go on as nicely as the first coat since the thinner softened the prior layer a bit. After the sides are on, the inside will all get more coats of varnish so I have another change to even it all out. It doesn't have to look great right now. It just has to give the wood enough color to avoid the glue white spots.
