RCU Forums - View Single Post - Preparing a fuselage for a former - question
Old 11-09-2009 | 11:37 AM
marc s's Avatar
marc s
Default Preparing a fuselage for a former - question
Guys currently building a Skygate Hawk and wanted to check something with you pros.
The fuselage is a sandwich construction with a layer of foam (guess nomex or similar) between the outer skin and the glassed inner surface finish - should I just scuff well (120 grit) clean and fit with Aeropoxy or does the foam need removing in the glueing areas to make a good joint?
marcs
