RE: Elevator alignment repair
Thanks CG!
After looking around im thinking Hinge points might be the way to go. Just not sure if there is enough support there in terms of wood on the leading and trailing edges. Do any of you guys install hinge points on ARFS without having to add wood stock to the control surfaces?
