quote:
Proper use of ailerons to counter a cross wind is required when the wind is not straight down the runway. Not understanding this is just as bad as not properly controlling the rudder.
ANY roll function requires input from the ailerons. His post sounds more like he's still on the ground and not yet airborne. If that's the case, aileron input can be a tad bit error prone.
From your reply, I'd guess that you do not understand the proper use of ailerons during a crosswind takeoff either. Yes, while still on the ground!
