ORIGINAL: Bdegan
Just bought this plane [8D]
I have all the servos and radio gear. I will be ordering the motor and ESC this week as I plan to do it up electric.
This is going to be my winter plane. I will also be leaving it in one piece for transport. That way on the cooler days or days just needing a quick fix. Throw it into one of the vehicles show up at the field pop in a battery, beat the plane silly. Throw it back into the car with no mess to clean...and another addict has his fix
I am ordering a lower kv motor than the rimfire 80. I will be using 6 cell on it. i have a whole bunch of 6 cell packs from my other plane that won't be used during the winter. It is the Giant Reactor with a hacker A60 setup. Great Big Foamie [>:]
Wow, I really like your thinking Bdegan. I have some 5S and 6S 5000 packs that won't get used this winter otherwise, so this could be a great excuse for me also. I recently checked the fit of the fully assembled plane into my ponticac grand am and it fits easily with the rear seat folded down.
Which motor wind are you getting and from where (also which prop?) I just visited the NeSail site and all options seem to require 10S:
http://www.nesail.com/detail.php?productID=4886
Have you used (or seen) your intended power combo used on an 8 lb 3D plane before? I was thinking of outfitting an OMP Fusion with electric power for the winter months, but that plane has considerable field assembly and the one piece nature of this plane is a very attractive option. Using magnets for the battery hatch will really simplify cold weather field access also.
Also, I"m curious will you be using skis or do you have access to a plowed/paved runway? You get snow up there too, don't you? If this works out I would order an extra set of gear for mine and put wheel pants for mud flaps and then quick change to another set with skis when the snow comes.
