ORIGINAL: fchris2
Hi there, after muckin around with lotsa other foamies, Ive decided to have a crack at an FJ. tried to get an arf but had to settle for buying one in parts. I forgot to get a motor mount and was hoping there a tried n true alternitive. Any one have ideas plese,
Thanks in advance.
P.s i`m running an inrunner
Well if you can wait you can order from tower hobby
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVL3&P=7
I looked on the web and no one has in stock.
You can use wire ties to mount the motor. You have install carbon fiber tube on the floor of the funjet. After that I use a balsa block then on top of the block I glue down a 1/16" piece of neoprene rubber to make sure the motor will not twist on the mount. The secert is to make sure the shaft of the motor is equal to or 1/16" below the back deck of the fuse.
