ORIGINAL: kitfox man
Thanks i will try that. I have it on a test stand. I will get the motor hot and back the bolts out and then put the loc- on the bolts.
Brian
You might try just tightening the bolts when hot. They lengthen when hot. Tightened then, at their operating temperature length, usually is adequate.
LocTite works for sure. When you don't have any and want to avoid the expense, or just want to fly the next day..............
