After giving a quick run, here are some thoughts:
Pros:
1. Excellent external finish.
2. Excellent suspension. The two front suspensions are even stiffer than the rest. Almost
too stiff.
3. Barrel is lathed aluminum.
4. Tools and miscellaneous parts are not molded-in and are located in the accessories box.
5. A metal gearbox.
6. I estimate the gun shoots at least at 150 fps.
7. It has a working front headlight that stays on as long as the unit is turned on.
Cons:
1. The unit sound is a bit low even at max setting.
2. No barrel recoil.
3. They painted over the front headlight. [sm=50_50.gif]
All in all, a great early Christmas present
