RE: 2stroke idle - a compromise?
check the easy, fuel line leaks, leaks on the engine, glow plug. I had an engine that ran good, but was problematic of dying at transition if I let it idle too long. I swapped out the A3 plug I was using, for a thunderbolt with an idle bar. that solved my problem.
