RCU Forums - View Single Post - FEJ planes: list of points to watch closely
Old 11-11-2009 | 08:03 PM
  #40
AndyAndrews's Avatar
AndyAndrews
Default RE: FEJ planes: list of points to watch closely
ORIGINAL: David Searles
Rex,
Glad to hear you got another F-18F. So did I! My original Diamondback is still flying, but showing the wear from the original issues with the gear etc, but the jet flies great, so I got one of the new, improved versions recently, in the AETE scheme. I'll assemble it over the winter and have it ready for spring flying. You will love the F-16. Just make sure it has the new gear upgrade and then only use manual valves like the BVM HiFlow for the retracts and you'll be good to go.
I also built a 1/5 AirWorld F-5 this summer. For what you get and have to do, compared to the FEJ, I'll happily work out the bugs on the FEJ rather than spend the bucks & go thru an Airworld build again!
I'll be flying all of my FEJ aircraft at Buttonwillow next week. F-15, F-16, F-18F & F-100 are all up and RTF, only a few bugs yet to work out on the F-15, but still looking forward to it. I'll try to get some video posted later.
David S
Ive been using the FEJ 5in1 valve on my Skymaster 1/6th F-16. I took the manual valve I had the screw type and replaced it with 4mm Festo valve. Works fine. I wish they would make the gear lock automatically without the valve but this will work until they do. I forgot to open the valve last weekend on a flight. lol, at least the gear is locked down when that happens ha.
Andy
Andy
