RE: small gasser
You've got me worried about that comment.... raising the port so much. It shouldn't be that much. Each little bit you take off the top of the port raises the timing "double" because the port opens sooner AND closes later. Are you sure you are measuring the full duration from opening to closing??
AV8TOR
