ORIGINAL: mstam1971
Now you made us very curious Jody about that complex fix
Is it the backplate, porting, ...?
No, It's not backplate porting.
The problem, as Jody so well indicated in his post before yours, is that it requires thought, time, materials, and a little skilled effort to perform. Done wrong and an engine has the possibility of not running at all, or running well for a little bit then not running after an improperly installed correction detached from its installed position. Ideally, you would not want just anybody making the attempt to manufacture and install a home brewed fix since so many are a little bit hazy about mechanical endeavors. We now live and play in a buy and fly hobby atmosphere and so very many that are involved are very limited in mechanical ability, and/or patience. For them to make attempts and then fail would only perpetuate the original issue and likely generate new ones, ones where they would wrongly want to hold the manufacturer responsible.
