DX7 ???
Hey all, might not be the right place, but I get all my good answers here. One of the other planes I picked up at the swap meet was a wattage extra 330L, nice little plane. Good friend of mine at the LHS hooked me up with a 2 wire speed controller for the brushed motor and tested the motor and it's good to go. I got it home and took the Spektrum Rxout of the typhoon. I selected the Typhoon model on the DX7 and powered everrything up. Light on receiver is flashing fast, but that's it. no stick repsonse. I tried rebinding with no luck. Any tips that would help me get it to bind? I'm putting the bind plug in the batt on the RX and the Receiver battery in the aux slot. I know I need to go to brushless, but nothing wrong with the motor that is in it. I can't remember where I hooked the ESC wire on the typhoon, but pretty sure it was the throttle slot. I can only assume it would be the same for the brushless motor. Servo's move and center when I power everything up. But after that, no solid light and no stick response.
