ORIGINAL: CSpierings I am starting to work on programming my first plane into the A9 and I want to set it up with flaperons as it does in my other radios. I have used the Acro mode and the indicated the plane has 2 aileron servos. The channels being 1 and 5 per the instructions for dual aileron servos. What is the recommended approach for programming flaperons? Do I use a PMIX and slave the channels? I am thinking that isn't the case because I already told the TX to use Ch 5 for the other aileron servo.Thanks
Depending on what you select, the radio will automatically optimize the functions for your choices.
In other words, if you select a wing type without flaps, there will be no flap function control.
Note options in that model memories programming.
1. Select "System Settings" > "MDLType"> Wing = "2AILE".
User will note Ch1 AILE:J1 Ch5 AIL2:J1 is preset when checked on the Channel menu.
2. Enter Model menu 2/2 select "FLAP CON" > Select "NULL" > select which switch you desire (e.g. "G") flaps to be on.
3. Return one screen, and set amount of flap control required for each of the two servos, say reduce from 100% (no movement) to 60% - 70% for both. User can also mix in "ELEV: 0%", increasing the "0" as desired.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
</p>
