RE: General question on fitting props
I put my new APC props on a dubro balancer to see where the hole center should really be. I will then use my bench drill press to ream the hole approx where it should be. I find that the final balancing is much easier this way. After you do a few props this way you get a pretty good idea of how far off center to ream the "new" hole.
