RCU Forums - View Single Post - adding right thrust
Old 07-05-2003 | 02:50 PM
Geistware
My Feedback: (16)
Default adding right thrust
I would say that grinding is not necessary for a plane that is under 1.20ci. Once you get to that size or larger, I would make sure the mount has as much surface area as possible. Remember, when you add a washer, you reduce the surface area that the engine torque and stress is transfered.
