RCU Forums - View Single Post - Pull Pull Rudder
Old 11-14-2009 | 09:19 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Pull Pull Rudder
Of key importance in any pull/pull installation is for the two surface horns clevis holes to be lined up perfectly laterally and through the exact hingeline of the surface. If there is any discrepancy in the alignment either fore or aft then differential will be induced and there will be a slack line situation on movement in both directions.
For all practical purposes the chief reason for pull/pull is to save weight aft of the CG for airplanes that may have tail heaviness problems. That sure applied to my Balsa Nova I built some years back. The Morris kits lumber was overly heavy at least in mine and the structure was a bit overdone. Take care in your CG considerations and the airplane is a great flyer however you will enjoy it. I recently gave the old bird away to the gentleman in the photo and he is sure enjoying it.
John
ID:	1313939   Click image for larger version
