ORIGINAL: pitstop000
Hello Cristiano,
This is for a fiberglass fuse and foam wing? What else is included? What needs to be supplied?
Can you check what shipping would be to the US?
Fuse is a 3 pieces all in fiberglass: nose, low part and top part where u can conceal pipe.
Foam wings are obeche covered with milled moving parts. Edges are included but to you only glue and sand them.
The parts to build and not included in the box are drawn to scale 1:1 (firewall, wings and tails tips and little else).
Wings are fitted with holes for the servos and the passage of the cables but everybody must make the holes for retractable gears.
