RCU Forums - View Single Post - Proud Bird Construction Thread
Thread
11-14-2009 | 10:53 PM
107
sahartman21
Nov 2007
2,060
Fritch, TX
RE: Proud Bird Construction Thread
You can mount the elevator horn on bottom or top of the elevator. A longer control horn can be used when mounting on top of the elevator.
The horns are made from music wire, sheet brass, a couple nuts, and silver solder.
A Dremel tool was used to grind out the area for the elevator horn.
Note that when the horn goes on top the gap-less hinge is located on the bottom of the control surface. [8D]
Reply
Like
sahartman21
View Public Profile
Send a private message to sahartman21
Find More Posts by sahartman21
View iTrader Profile
