RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
<div id="post_message_13585980">Help is needed:
I'm not being able to put the servos moving the correct direction in a T-Rex Heli Swash Type (3 servos 120º);
The "Servo Reverse" option is not enough, to put the three servos moving the correct way for AILE, ELEV and PITC; if AILE is Ok, then PITC is not and if I correct PITC the others became wrong... (as you know, all the three servos move at the same time in order to have a correct move of the Swash Plate, for PITC for example).
How can i reverse the direction of one servo only, in this case, without change all the Swash movements?
Thank you. </div>
