RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 11-15-2009 | 02:46 PM
A.T.
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
ORIGINAL: Bob Pastorello Using the Aurora with the Aerofly ProDeluxe Flight Sim - after much head scratching, I realized that the "native" Aurora with the 2.4 G module installed isn't "recognized" by the AFP USBInterface. Fix was quite simple; unplug the module. Sim came up immediately, and after creating a profile in the Sim and calibrating it, works just fine. Apparently "something" in the output of the trainer jack honks up the AFP interface.
The Aurora also does *not* require to be setup in Trainer mode. Works slicker 'n snot.
Thanks, Aerofly ProDeluxe Flight Sim not available to test locally. Aurora - Simulator function Set-up has been amended with a link to your post.
Q: After removal of module, insertion of USBcable/dongle, was there any difference if TX used in "Transmit" Yes or No or mode?
Alan T.
