RCU Forums - View Single Post - ARC Jupiter
Thread: ARC Jupiter
Old 11-15-2009 | 09:45 PM
  #62
red head
Default RE: ARC Jupiter
Tex: On one of the Jupiters I ran into in my travels a fellow was having the same problem with his landing gear block. He had cleaned up the block, roughed it up and reglued it, then screwed screws into it from outside. I've had a couple come loose but it was because I didn't " SCORE " the areas to be glued. On some of them I was pretty rough on them.
The screw cure is pretty drastic but it should work. Just remember that the block is hollow. If you can, clean the area to be glued really good then " SCORE " the areas to be glued. I use a hobby knife and really score/ scratch the heck out of all areas to be glued. If anyone is reading this that plans on assembling a Modelfly plane, I suggest that you SCORE ALL the areas to be glued, it really helps.
I guess if all else fails you might want to try the screw deal. ENJOY !!! RED
