Help! Spring Air Steerable Nose Wheel
rcman58 and Thud_Driver
Yes this unit only has one push rod. I have kept the linkage on a line parallel with the pivot point but the plastic slide linkage twists as the retracts are going down and this creates the problem. I have a nylon clevis on the linkage should I remove this and just use a "z" bend? Since the plastic linkage is already mounted how do you get a spring mounted between the arm and the plastic linkage?
