RCU Forums - View Single Post - Help! Spring Air Steerable Nose Wheel
Old 07-04-2003 | 09:03 PM
IFR
Default Help! Spring Air Steerable Nose Wheel
I hate to profess my ignorance, but what is a standoff? The retract is on a Wing Mfg P-38 which has a narrow center fuselage so I will have to get the twisting down to a minimum. I also noticed that the rod on the arm is shorter than the distance the linkage travels during retraction, this is adding to the bind so if it can be unscrewed I will look at installing a longer rod.
