RCU Forums - View Single Post - Balsa Nova fliers
Old 11-16-2009 | 11:24 AM
billd76's Avatar
billd76
Default Balsa Nova fliers
Thanks for all the advice thus far, but have a couple more ???'s. What did you do about engine thrust alignment? I don't see any noticable thrust built in. And What about the thottle rod connection? Did you take yours down beside the fuel tank or some other way? Looks like a good deal of bending will be required for the throttle rod either way. Did you mount your battery in with the fuel tank, or in the fuse? Did you use a mirco servo for the thrortle or standard size? Have you thought about mounting a servo outside the fuse near the rudder instead of using a pull pull setup? I will go with the pull pull, just wondering what your thoughts were on mounting an external servo in place of it.
