RE: 2stroke idle - a compromise?
Another 'test' to find out if the fuel/air mixture is correct is to set the throttle at idle and pinch the fuel line to the carb. If the engine revs and dies it's too rich. If it quits immediately it's too lean. IF it runs a cpl seconds then quits it should be adjusted right.
Good Luck
Tom
