RE: Why does it do it?
Your high-end needle is too rich. Just because it seems tuned to run on the ground, doesn't mean it will work in the air. The needle settings on the ground are a rough adjustment only. Once you get it in the air, see how it sounds, land and adjust and repeat until it runs good.
