RE: 2stroke idle - a compromise?
The pinch test is particularly good at high throttle settings, but most engines are not responsive to a pinch test at idle.
I've seen properly tuned engines continue to run for 15 seconds and more with the fuel line pinched, where-as at high throttle the results are immediate.
The rather low and slow fuel flow at idle masks the result of a pinch test.
The ignitor removal lets you quickly focus on an approximate setting. Then you can use a pinch test to verify the results. Fully pinched off the engine should run, and then after a while briefly speed up and finally stop once tuned.
