RE: Spad to the Bone Dominator Problem
hey Norbon, hmmm, it sounds like you need to adjust your ailerons up a little, if they are drooping a little, it will force the nose down. Im not sure if that plan explans it but some of the others do. when you look at the end of the wing, the alierons should be parallel to the fuse, your elevator might also need a slight adjustment also make sure your wing center line is parrallel to the fuse, incidence might be off a little
