ORIGINAL: carlgrover
I like Zippi's method but what I do is cut all the hinges off and re-hinge the entire control surface, just to be sure.
carlgrover,
Just the hinge that has play in it is the only one you'll need to do as I described about. That is the reason for doing this so you don't have to remove the control surface to replace the hinges.
