RE: ARC Jupiter
Hey Red. Thanks for that tip. I found 2 plastic pins that come with the kit. I drilled hole from the outside and glued them in to hold that landing block. Looking good, just have to see at the field. One of the wheel popped during take off, so I landed with one wheel and nosed over, broke the tip of my blue 11x7 propeller. It is replaced with a wood prop now. There is a little nut that hold the wheel to the strut. This nut should be CA in place before screw the wheel in. I want to paint the prop blue, but afraid the paint adds weigh and shift the prop balance. Any advise?
