I understand that there really is no more Aerotrend.... Has anyone found a source for the same type of material?
I'm using a McMaster Carr coupler material
McMaster Number = 5236K951
(Same as 5236K95)
Silicone Rubber Tubing Soft, 3/4" ID, 1" OD, 1/8" Wall, Blue
Quantity Per Ft.
1-99 Ft. $3.43
I don't believe this to be nearly as robust as the Aerotrend stuff I used to buy as exhaust extensions so if anyone knows the Aerotrend source can you share the info
Thank you,
Chris
